It is currently Fri May 29, 2020 5:36 am
Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
 Post subject: Using 4ze1 dizzy for crank angle sensor Q's
PostPosted: Fri Aug 24, 2012 11:03 am
I'm going to use a 4ZE1 dizzy in my piazza engine for a crank angle sensor to run a sequential injection and coil setup.
I had a look at the shutter wheel in the dizzy and it has 360 small holes and 4 larger slots for each cylinder tdc. The ecu will need a no#1 cylinder TDC referance. Therefore 1 larger slot will be needed. What have others done here?. Cut one of the slots bigger?. Fitted a different shutter wheel from another Dizzy, sr20 etc?.
Cheers.
1977 tc gemini
PostPosted: Fri Aug 24, 2012 5:01 pm
I use one in my c1 with megasquirt I painted all but 1 of the 360 slots and run it as a 4-1 cas it works well.
PostPosted: Fri Aug 24, 2012 5:15 pm
That sounds like a fairly good idea. I thought I might make one of the 4 slots longer than the others. Apparently most aftermarket ECU's don't like using the 360 slots so your idea might be better.
What type of paint did you use?. I presume you just used the paint to fill the holes in?.
1977 tc gemini
PostPosted: Fri Aug 24, 2012 6:28 pm
Just black vht engine enamel should have used maybe a epoxy type paint but was all I had and I was keen to see if it would work and it does it's been like that for three years. The firing order is 1342 so you leave one slot between 1-2 and set your ecu up to recognize that type of tach signal.
PostPosted: Sat Aug 25, 2012 12:21 pm
i cut and shut my piazza dizzy and fitted an sr20 CAS.... but this was before i knew i could use the 4ze1 SIGH....
Previously Known As gemzilla1
PostPosted: Sun Aug 26, 2012 10:03 am
I have a couple of piazza dizzies laying around. I was looking at changing the internals to a 2.6 magna as I also have one of those laying around. It's just easier and nearter to use the 4ze1 unit.
Thanks for all the help.
1977 tc gemini
PostPosted: Sun Aug 26, 2012 6:05 pm
i'm looking at making a small diameter billet cas for the 4Z in my car so i can move the engine back to normal gem mounts
PostPosted: Sun Aug 26, 2012 9:32 pm
I machined a magna one for my g200 Was a piece of piss just machined the original shaft and roll pinned it to the magna dizzy. I'm not sure about z's though
 Post subject: Re: Using 4ze1 dizzy for crank angle sensor Q's
PostPosted: Mon Dec 07, 2015 10:39 pm
Could some one please help me out with the easiest way to use the 4ze1 dizzy sensor to trigger my aftermarket ecu. I'm wiring up a megasquirt but I don't believe it will read it. I thought about making it into a 36-1 trigger but the slots are so small it wouldn't be easy and might cause me tuning difficulties if it's not exact.
Many thanks. If I come up with something in the mean time il post it up.
PostPosted: Tue Dec 08, 2015 8:15 am
viewtopic.php?f=29&t=27104
PostPosted: Sat Dec 12, 2015 11:44 am
Megasquirt? You're keen.
PostPosted: Sun Dec 13, 2015 10:18 pm
Yeah I reckon I could have got a diploma in the time I spent researching, building and wiring my Megasquirt. I'm happy with the end result though, although I may need to reroute a couple of wires to get a more accurate signal.
PostPosted: Sat Dec 19, 2015 4:58 am
I ended up getting a 12-1 trigger disk from diyauto tune. I had Lo-resolution signal issues while cranking with the factory 4ze1 trigger disk.
PostPosted: Thu Feb 04, 2016 12:44 am
Interesting, mine is pretty hard starting and I think may be experiencing poor CAS input also. I'm only using the four pulse per dizzy rotation output currently. Is that what you were using too? Was it hard to fit the 12-1 trigger disk to the E1 dizzy and did it solve your issue?
Very interested! Cheers,
Eli
PostPosted: Sun Feb 07, 2016 8:15 am
Yes it helped only get the odd cranking issue now caused from voltage drop.
Users browsing this forum: No registered users and 3 guests
